clear counters cfm segment all frame-loss
Description
This command clears only frame-loss information for all existing segments.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
Use this command to clear only frame-loss information for all existing segments.
# clear co cfm seg all frame-loss
# sho cfm segment
CFM Segment Name                : cs10
Domain Name                     : dom1
Association                     : a10
MD Level                        : 1
Destination MAC                 : 00:04:96:52:a7:38
Frame Delay:
DMM Transmission             : In Progress
Transmission Mode            : On Demand
Total Frames to be sent      : 45
Frames Transmitted           : 2
Pending Frames               : 29
Frames Received              : 2
DMM Tx Interval              : 10 secs
DMR Rx Timeout               : 50 msec
Alarm Threshold              : 10 %
Clear Threshold              : 95 %
Measurement Window Size      : 60
Class of Service             : 6
Tx Start Time                : Mon Mar 12 10:28:59 2012
Min Delay                    : Mon Mar 12 10:29:09 2012
Max Delay                    : Mon Mar 12 10:29:09 2012
Last Alarm Time              : None
Alarm State                  : Not Set
Lost Frames                  : 0
Frame Loss:
LMM Tx Interval              : 10 secs
SES Threshold                : 1.000000e-02
Consecutive Available Count  : 4
Measurement Window Size      : 1200
Total Configured MEPs        : 1
Total Active MEPs            : 1
MEP ID                    : 10
LMM Transmission          : In Progress
Frames Transmitted        : 0
Pending Frames            : 29
Frames Received           : 0
Availability Status       : Idle
Unavailability Start Time : None
Unavailability End Time   : None
Tx Start Time             : None
CFM Segment Name                : cs11
Domain Name                     : dom1
Association                     : a11
MD Level                        : 1
Frame Delay:
Pending Frames               : 29
Frames Received              : 2
Max Delay                    : Mon Mar 12 10:28:59 2012
Lost Frames                  : 0
Frame Loss:
MEP ID                    : 11
Pending Frames            : 28
Frames Received           : 0
Tx Start Time             : Mon Mar 12 10:29:19 2012
CFM Segment Name                : cs12
Domain Name                     : dom1
Association                     : a12
MD Level                        : 1
Frame Delay:
Pending Frames               : 29
Frames Received              : 2
Total Configured Segments       : 11
Total Active Segments           : 11
This command was first available in ExtremeXOS 15.1.
Platform Availability
